dbarrow
Sep 01, 2021Aspirant
Fast speed on two computers (480Mbps) slow on all others, phoes, etc. (96Mbps). RBR850, RBS850
I just purchased an RBR850/RBS850 setup. Everything seems to work, but only two wired computers get fas 480Mbps speed, whil EVERYTHING else, computers, phones, tablets, etc. get slightly less than 10...
- Sep 02, 2021
SOLVED! Apparently the slower speed was caused by a poor cable connection in one of our 110 punch down blocks. I am on oxygen, recuperating from Covid (low energy to solve problems or do much physically). I showed my wife how to use a punch down tool and she went up in the attic and "reasserted" all the punch down connections on the terminal strip. Before Orbi, I have seldom intermittant connections, but I did have the occasional issue. I think Orbi is more sensitive to cable/connection quality and downgraded a whole section of our network to 100Mbps. Anyway, all fixed now. Thanks for your help.
Sep 01, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto?
Armor, AX mode on the RBR.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- dbarrowSep 01, 2021Aspirant
3000sf home
Satellite using ethernet back haul
Time Warner Spectrum Arris cablemodem
Speedtest 480Mbps
I can't find where to disable Armor or those other things you mentioned. My previous setup, with two Netgear routers, all computers could get 400+ Mbps with Speedtest. Orbi has been a huge downgrade so far. Most computers connected even by ethernet to the main router get 96Mbps.- FURRYe38Sep 01, 2021Guru - Experienced User
You can disable Armor via the Orbi app and selecting the Armor tile there. There will be a disable option under this section.
There a model# of the cable modem?
What are these two computers? Brand and model?
What is the brand and model of the ethernet adapters in these PCs?
Ensure the drivers for these adapters are up to date.
Ensure good quality LAN cables are being use. CAT6 is recommended.
The two computers that get the fast speed were custom built ten years ago. All the computers on out network got 480Mbps before the Orbi upgrade. The computers that get the slow speeds are mostly much newer. All computer run Windows 10 21H1 and are constantly updated. I can connect ANY other compuet directly to the Orbi main router and it will get 96Mbps. That speed is very consistent. It's like the router ok'd thos two computers for 480Mbps and all others are bumped down to 100Mbps speed. What would cause that?
