dbarrow
Sep 01, 2021Aspirant
Fast speed on two computers (480Mbps) slow on all others, phoes, etc. (96Mbps). RBR850, RBS850
I just purchased an RBR850/RBS850 setup. Everything seems to work, but only two wired computers get fas 480Mbps speed, whil EVERYTHING else, computers, phones, tablets, etc. get slightly less than 10...
- Sep 02, 2021
SOLVED! Apparently the slower speed was caused by a poor cable connection in one of our 110 punch down blocks. I am on oxygen, recuperating from Covid (low energy to solve problems or do much physically). I showed my wife how to use a punch down tool and she went up in the attic and "reasserted" all the punch down connections on the terminal strip. Before Orbi, I have seldom intermittant connections, but I did have the occasional issue. I think Orbi is more sensitive to cable/connection quality and downgraded a whole section of our network to 100Mbps. Anyway, all fixed now. Thanks for your help.
Sep 01, 2021Guru - Experienced User
I recommend you contact NG support and ask for there help. Possble you may have a faulty system.
dbarrow
Sep 02, 2021Aspirant
- FURRYe38Sep 02, 2021Guru - Experienced User
Glad you finally found the problem.
Please mark your thread as solved so others will know.
Enjoy.
