bmwr75
Dec 14, 2021Star
Fiber Modem and Orbi connectivity problem
Recently purchased the Netgear Orbi RBK753S High-Performance Whole Home Mesh WiFi System from Amazon. Cannot get it to work when connected directly via ethernet cable to my Adtran SDX 621 fiber mode...
- Dec 17, 2021
My ISP did an update on their fiber modem ONT and the Netgear Orbi started working as it should after a restart.
bmwr75
Dec 14, 2021Star
Called my ISP today and tech support said many of their customers use their own routers and mine should work fine. FYI - the Google Mesh router this Orbi replaced didn't work either when connected directly to the fiber modem via ethernet cable.
I turned off the radio on the ISP provided router in the router's set up menu.
CrimpOn
Dec 14, 2021Guru - Experienced User
sometimes it helps to power off the ONT, attach the WiFi router, power on the ONT, (wait a minute until the network light comes on), then power on the WiFi router (Orbi). Enter the Orbi web management interface and see what it says about the WAN connection.
- bmwr75Dec 15, 2021Star
CrimpOn wrote:sometimes it helps to power off the ONT, attach the WiFi router, power on the ONT, (wait a minute until the network light comes on), then power on the WiFi router (Orbi). Enter the Orbi web management interface and see what it says about the WAN connection.
Thanks for the recommendation, tried it and did not work. Orbi admin screen said no internet connection. Also tried the other suggested power up sequence suggested in the other duplicate thread and it didn't work either. Have got a help ticket started with my ISP now.
- FURRYe38Dec 15, 2021Guru - Experienced User
Ask the ISP if there is any user account settings needed for there ONT to connect with external routers. Not sure if your ISP may have this or not. Usually Fiber ISPs is mostly DHCP up to the ONT and no account information needed.
Hope they can figure it out.
- bmwr75Dec 16, 2021Star
Contact my ISP tech support yesterday. They said they need to install a new "package" so I can use a third party router.
