Mikestarting
Dec 03, 2021Aspirant
Fiber Optic + Meshwifi Orbi Pro Wifi 6, how do you do that? Lost...
Hi dear community, it's my 1st post here :smileysurprised: I'm new... And don't have huge skills with hardware. Maybe someone can help me, this must be something frequent: how and if there's a sol...
Dec 03, 2021Guru - Experienced User
Not sure about the list but most fibre companies have an ONT. That'd be a box that converts the fibre signal to ethernet. If they supply you with one of those, you can directly connect the orbi. If they don't, then you might need the gateway they recommend. but you're not required to put the orbi in access point mode. You could simply put the orbi's ip address into the gateway's DMZ. Then it automatically forwards all traffic.
Mikestarting
Dec 04, 2021Aspirant
Thanks a lot plemans for your answer, I'll for sure check both methods you mention!
