cerise-front0z
Jul 01, 2024Aspirant
Find out client actual connection type WPA2 or WPA3
Configured wireless setup as WPA2-PSK [AES] + WPA3-Personal [SAE] How to find out if a client connection uses WPA2 or WPA3 using web interface or Orbi App? On Attached Devices, I can see the cli...
- Jul 01, 2024
Welcome to the Apple world ... Most likely, you have to install the developers WiFi profile for debugging..
Start here https://developer.apple.com/bug-reporting/profiles-and-logs/
You have to agree to the developers agreement after you sign in with your Apple ID.
You can then install the profile, under your WiFi there will be a Diagnostic menu..
Needless to say, Netgear Insight does show the related security for the connected client.
cerise-front0z
IMO, since the router needs to negotiate WPA2/WPA3 (or even WPA) connection type for each client, it has to maintain which type of a client connection is used in the other end. So, the data traffic can be properly encrypted or decrypted based on type. If the minor enhancement could be supported on the router GUI, it is quite helpful tool to identify all client connections in one place. Just a thought.
Jul 01, 2024Guru - Experienced User
Wifi security is ONLY for the connection between the router system and connecting devices, i.e. Connection Type. It doesn't encrypt or decrypt data traffic going in between the system and devices.
