cerise-front0z
Jul 01, 2024Aspirant
Find out client actual connection type WPA2 or WPA3
Configured wireless setup as WPA2-PSK [AES] + WPA3-Personal [SAE] How to find out if a client connection uses WPA2 or WPA3 using web interface or Orbi App? On Attached Devices, I can see the cli...
- Jul 01, 2024
Welcome to the Apple world ... Most likely, you have to install the developers WiFi profile for debugging..
Start here https://developer.apple.com/bug-reporting/profiles-and-logs/
You have to agree to the developers agreement after you sign in with your Apple ID.
You can then install the profile, under your WiFi there will be a Diagnostic menu..
Needless to say, Netgear Insight does show the related security for the connected client.
schumaku
Jul 01, 2024Guru - Experienced User
cerise-front0z
I checked out the debug profile and installed on my two Apple devices. They did show Security type (like WPA2 vs WPA3). But I had to create a developer account and downloaded the profile for each device. It seems doable but a couple of extra steps. Thanks.
