Geddy007
Mar 29, 2022Aspirant
Firestick loses connection to router
I have a frustrating issue with my Firestick 4k. My system is an RBR750 router with 2 RBS750 satellites connected wirelessly in daisy chain (it's a long house). The Firestick is literally 4 feet...
Mar 29, 2022Guru - Experienced User
IT's up to devices to pick and chose where they connect too.
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try setting 40Mhz only coexistence Under Advanced Tab/Advanced Settings/Wireless Settings
