skeelo
Nov 26, 2020Luminary
Firmware 3.2.16.22
Anyone update to the latest firmware for their RBR850? Any issues? What is the BDF table?
Jan 13, 2021Guru - Experienced User
What mode is your modem working in? Your modem already has a built in router and wifi:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
TomNewe wrote:I have updated twice and twice had to revert to previous version as the Router wouldn't give access to the Internet (Connected via a Huawei F2000 Modem) after about 12 hours active. Second time even a reboot didn't solve the problem.
TomNewe
Jan 14, 2021Aspirant
Thank you FURRYe38 I will try that. I dont think i can use Bridge mode as I use VOIP on the F2000 and Bridging it would disable it. I may need to move some equipment around in order to use the VOIP port on the RBR850 or try option 2 or 3 that you sent me.
- FURRYe38Jan 14, 2021Guru - Experienced User
Ok, option 2 or 3 will definately help.
- TomNeweJan 14, 2021Aspirant
Hi FURRYe38 Can i ask if it is necessary to disable the WiFi on the IPS router when the Orbi is in AP mode. I haven't done this and the Orbi still drops internet access intermittently and then i use the original ISP router WiFi
It's recommended to disable wifi on the ISP router.
