skeelo
Nov 26, 2020Luminary
Firmware 3.2.16.22
Anyone update to the latest firmware for their RBR850? Any issues? What is the BDF table?
killswitch83
Mar 29, 2021Guide
I too have a RBR850, and am experiencing dips in internet speed. I will have to get back to you guys on Spectrum router model, but it doesn't have built-in wifi (had to use their separate module). Running an Asus USB wifi dongle (again, will get back to you on model). After successfully performing setup, it updated the firmware immediately after. Worked fine for a few, but when we started streaming Netflix and I was using my desktop, that's when I noticed the fluctuating performance. Any suggestions? Thanks in advance!
- FURRYe38Mar 29, 2021Guru - Experienced User
Is this only seen with the RBR alone or do you have RBS deployed as well?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-tWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347.
under Advanced Tab/Advanced Settings/Wireless Settings
killswitch83 wrote:
I too have a RBR850, and am experiencing dips in internet speed. I will have to get back to you guys on Spectrum router model, but it doesn't have built-in wifi (had to use their separate module). Running an Asus USB wifi dongle (again, will get back to you on model). After successfully performing setup, it updated the firmware immediately after. Worked fine for a few, but when we started streaming Netflix and I was using my desktop, that's when I noticed the fluctuating performance. Any suggestions? Thanks in advance!- killswitch83Apr 02, 2021Guide
Hi Furry,
To answer some of your questions here:
-I have a satellite deployed, at the appropriate distance from the router, as recommended below (30+ feet). House is 2100 sq. ft., with normal building materials (wood, drywall either 3/8" or 1/2" thick)
-I counted approximately 23 different wifi entries via NirSoft wifiinfoview, the vast majority of which belong to the apartment complex across the street from me (very weak signals).
-I adjusted all of the settings mentioned below, but with no luck. Disabling AX didn't do anything, either. An obersevation though: whenever my girlfriend goes to stream on her cell-phone, in the same area as the router, that's when things start slowing down for my desktop. If she does the same streaming on her laptop, however, the speed goes back up for the desktop, to speeds I usually see. Also of note: if she streams on her cell in the back bedroom, which is away from the router and is running on the satellite instead, there's no issue there either. Any input as to why any of this is? For now, as it seems optimal, she'll be using her laptop to stream and do bandwidth-intensive tasks when near the router.
- FURRYe38Apr 03, 2021Guru - Experienced User
What brand of phone is she using?
What kind of streaming is she doing? What app?
What is the wifi adapter brand that you have on your PC?
Are you speed testing when she is streaming or just doing normal stuff?
