skeelo
Nov 26, 2020Luminary
Firmware 3.2.16.22
Anyone update to the latest firmware for their RBR850? Any issues? What is the BDF table?
killswitch83
Apr 03, 2021Guide
She has a Samsung S10, streaming HD video via Netflix. My wifi adapter is an Asus USB-AC53 Nano, which is an AC1200 adapter. I have speed-tested under load with her phone in the router vicinity (signal drop-out occurs here), no load on her phone but on my PC (router vicinity, normal speeds here), load on her laptop and my desktop on the router side (normal speeds), and then loads on both my PC and her phone (with her phone being on the satellite side of the house, and my desktop on the router side: normal speeds observed here also)....
Apr 03, 2021Guru - Experienced User
Be sure your NANO drivers are up to date as well.
Is the NANO a 2.4 only or a dual band adapter?
- killswitch83Apr 03, 2021Guide
The driver is up to date, and I forgot to mention that it's a dual-band adapter.
- FURRYe38Apr 03, 2021Guru - Experienced User
Shouldn't be seeing any bandwidth issues. Seems like your adapter is getting starved when the streaming happens when your both on the same RBR wifi.
Only other thing I might try would be a different adapter on your PC.
- killswitch83Apr 10, 2021Guide
As it turns out, you were correct concerning the adapter: that little Asus AC53 (AC1200) couldn't hang with the heavy load demand coming from all the other devices to the router. Swapped it out with a Netgear A7000-10000S AC1900 adapter, and everything is stable as can be. Consistently fast Speedtest (and real-world) speeds, even with all devices running at full-bore, streaming and the like. Thanks for the help and suggestions!
