skeelo
Nov 26, 2020Luminary
Firmware 3.2.16.22
Anyone update to the latest firmware for their RBR850? Any issues? What is the BDF table?
Apr 03, 2021Guru - Experienced User
Shouldn't be seeing any bandwidth issues. Seems like your adapter is getting starved when the streaming happens when your both on the same RBR wifi.
Only other thing I might try would be a different adapter on your PC.
killswitch83
Apr 10, 2021Guide
As it turns out, you were correct concerning the adapter: that little Asus AC53 (AC1200) couldn't hang with the heavy load demand coming from all the other devices to the router. Swapped it out with a Netgear A7000-10000S AC1900 adapter, and everything is stable as can be. Consistently fast Speedtest (and real-world) speeds, even with all devices running at full-bore, streaming and the like. Thanks for the help and suggestions!
- FURRYe38Apr 11, 2021Guru - Experienced User
Glad you found something that works.
Enjoy. :smileywink:
killswitch83 wrote:As it turns out, you were correct concerning the adapter: that little Asus AC53 (AC1200) couldn't hang with the heavy load demand coming from all the other devices to the router. Swapped it out with a Netgear A7000-10000S AC1900 adapter, and everything is stable as can be. Consistently fast Speedtest (and real-world) speeds, even with all devices running at full-bore, streaming and the like. Thanks for the help and suggestions!
