AwesomeQA
Aug 17, 2020Apprentice
Firmware 3.2.16.6 Web GUI bug
I have updated RBR850 to Firmware 3.2.16.6. Once you change any device name in the attacjed device list, all devices will disappear from the attaced devices. I did hard reset the Router, and chang...
Jan 27, 2021Guru - Experienced User
I can verify on my 8 series with v12 loaded, that after changing the device name and icon and applying the change, the device list appears and the change is correct:
dtay
Jan 27, 2021Luminary
FURRYe38 wrote:I can verify on my 8 series with v12 loaded, that after changing the device name and icon and applying the change, the device list appears and the change is correct:
Have you tried doing it via the app? On my Android app (v2.8.0.1395), when I change the icon (e.g. a Ring doorbell is misidentified as something else by the icon, so I changed it to the doorbell icon) to the correct type, it saves it but when I refresh, it loses the changes.
Same problem via the web GUI as well. I make the changes and it doesn't retain it. Firmware V3.2.16.22_1.4.9 on 850's.
