skuhn
Apr 13, 2022Follower
Firmware downgrade of RBR750 from V4.6.7.13 to 3.x
I updated my firmware on this weekend from a 3.x to 4.x version. This lead to back-haul problems with the satellite. It's working after reboot for a couple of minutes and then starts to blink white u...
Apr 13, 2022Guru - Experienced User
First off how did you update FW to v.13? Manually or Auto update? Manually is recommended.
Did you first update the RBS then RBR?
Is the RBS wireless or wire connected to the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Downgrading to v3 FW is not supported.
