gerardo8a's avatar
gerardo8a
Firmware stuck
Today a new firmware showed up so I did click on the upgrade firmware, after upgrading the main router and one satellite show the latest firmware V4.6.9.11 but one shows the previous one v4.6.8.5 in ...
  • FURRYe38's avatar
    Oct 25, 2022
    After you loaded FW on the RBS first then RBR lastly, did you power OFF the units for 1 minute then back ON.
    Just seems like the status is falsely reporting the prior FW version and hasn't fully updated yet.
    gerardo8a wrote:
    Today a new firmware showed up so I did click on the upgrade firmware, after upgrading the main router and one satellite show the latest firmware V4.6.9.11 but one shows the previous one v4.6.8.5 in the current version column and in the status it says with a link V4.6.3.16
    Then I decided to download the firmware and apply it to that satellite manually, which I did and then the table shows like this
      Model Name Device Name Current Firmware Version Status
    Router RBR850 RBR850 V4.6.9.11 No New Firmware Available
    Satellite RBS850 Orbi Satellite-1 V4.6.9.11 No New Firmware Available
    Satellite RBS850 Orbi Satellite-2 V4.6.9.11  V4.6.3.16
    Why it wants to update to an old version?
