gerardo8a
Oct 24, 2022Aspirant
Firmware stuck
Today a new firmware showed up so I did click on the upgrade firmware, after upgrading the main router and one satellite show the latest firmware V4.6.9.11 but one shows the previous one v4.6.8.5 in ...
- Oct 25, 2022
After you loaded FW on the RBS first then RBR lastly, did you power OFF the units for 1 minute then back ON.
Just seems like the status is falsely reporting the prior FW version and hasn't fully updated yet.
gerardo8a wrote:
Today a new firmware showed up so I did click on the upgrade firmware, after upgrading the main router and one satellite show the latest firmware V4.6.9.11 but one shows the previous one v4.6.8.5 in the current version column and in the status it says with a link V4.6.3.16
Then I decided to download the firmware and apply it to that satellite manually, which I did and then the table shows like this
Model Name Device Name Current Firmware Version Status Router RBR850 RBR850 V4.6.9.11 No New Firmware Available Satellite RBS850 Orbi Satellite-1 V4.6.9.11 No New Firmware Available Satellite RBS850 Orbi Satellite-2 V4.6.9.11 V4.6.3.16 Why it wants to update to an old version?
gerardo8a
Oct 25, 2022Aspirant
The problem was the RBR , it needed to be rebooted . for some reason it kept reporting the wrong version, I also rebooted the satellites i believe they need it to to report back, anyway rebooting all after an update make things work again
thanks!
thanks!
Oct 25, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
