donawalt
Aug 15, 2020Hero - Experienced User
Firmware update - 3.2.16.6
My router just updated to 3.2.16.6, there doesn't appear to be any documentation yet on what's changed. Does anyone have access to that information? Thanks!
AwesomeQA
Aug 15, 2020Apprentice
This version doesn't show the devices and sats.
I hope it is stable though.
donawalt
AwesomeQA what do you mean it dosn't show devices and stats? I can't see your to images, they show as yellow triangles. If you are talking about the "Attached Devices" page, I see them all there listed as before.
- AwesomeQAAug 15, 2020ApprenticeYes, attached devices don’t show for me.
I did hard reset for RBR850 and sats.- Chuck_MAug 15, 2020Mentor
Works Fine so far for me... RBR850, RBS850 and 2 x RBS50s.
[Enhancements] Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately.
[Enhancements] Includes some security enhancements.
[Enhancements] Supports the IGMP over the PPPoE WAN connection.
[Enhancements] Supports the profile configuration to set up the ISP's VLAN/IPTV settings during installation. The following are the limited ISPs that are supported currently: France Orange;Singapore SingTel;Malaysia Unifi, Maxis.
[Bug Fixes] Fixes some GUI related issues.
