donawalt
Aug 15, 2020Hero - Experienced User
Firmware update - 3.2.16.6
My router just updated to 3.2.16.6, there doesn't appear to be any documentation yet on what's changed. Does anyone have access to that information? Thanks!
Edwardlotz
Aug 16, 2020Guide
Release notes below but see my issue if someone has an idea of how to fix.
My firmware is v3,2,15,32. In firmware update page it show the ability of this new firmware but update all is greyed out and I can not upgrade to this new firmware. Also the satellite firmware doesn’t show correctly and it says service unreachable. I have been having to manually update both the router and satellite sine the firmwares software auto Update will not work anymore. Any suggestions.
However it does show the change log for the new firmware:
Release Notes:
[Enhancements] Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately.
[Enhancements] Includes some security enhancements.
[Enhancements] Supports the IGMP over the PPPoE WAN connection.
[Enhancements] Supports the profile configuration to set up the ISP's VLAN/IPTV settings during installation. The following are the limited ISPs that are supported currently: France Orange;Singapore SingTel;Malaysia Unifi, Maxis.
[Bug Fixes] Fixes some GUI related issues.
An
Release Notes:
An
Aug 16, 2020Guru - Experienced User
Please respond here to your post:
Release Notes:
An
