Deepak_Mehta
Mar 03, 2021Aspirant
Firmware Update Issue
My RBR850 is updated but my RBS are not getting updated.
- Mar 03, 2021
If you had a wired PC connected to the system there and had a remote control program like Teamviewer installed on the PC, you could update the RBS remotely. If not, you'll need to be onsite.
Mar 03, 2021Guru - Experienced User
Have you tried manually updating firmware to it?
How do I check and manually update the firmware on my Orbi satellite? | Answer | NETGEAR Support
