Deepak_Mehta
Mar 03, 2021Aspirant
Firmware Update Issue
My RBR850 is updated but my RBS are not getting updated.
- Mar 04, 2021
If you had a wired PC connected to the system there and had a remote control program like Teamviewer installed on the PC, you could update the RBS remotely. If not, you'll need to be onsite.
Mar 03, 2021Guru - Experienced User
Have you tried manually updating firmware to it?
How do I check and manually update the firmware on my Orbi satellite? | Answer | NETGEAR Support
Deepak_Mehta
Mar 04, 2021Aspirant
For RBR i was'nt taking the update from internet, i have done it manually, but RBS i am not able to do it.
- FURRYe38Mar 04, 2021Guru - Experienced User
Are you logging on to the RBS web page and sending the FW direclyt to the RBS there using there web pages? You can do this if the updating process doesn't work from the RBRs web page.
- Deepak_MehtaMar 04, 2021Aspirant
The problem is that i am sitting on a remote location, due to which i can access RBR remotely, but cant access RBS from outside.
Is there any other solution from which i can do that.
Can also follow this guide as well...
