Deepak_Mehta
Mar 03, 2021Aspirant
Firmware Update Issue
My RBR850 is updated but my RBS are not getting updated.
- Mar 03, 2021
If you had a wired PC connected to the system there and had a remote control program like Teamviewer installed on the PC, you could update the RBS remotely. If not, you'll need to be onsite.
Deepak_Mehta
For RBR i was'nt taking the update from internet, i have done it manually, but RBS i am not able to do it.
Mar 03, 2021Guru - Experienced User
Are you logging on to the RBS web page and sending the FW direclyt to the RBS there using there web pages? You can do this if the updating process doesn't work from the RBRs web page.
- Deepak_MehtaMar 03, 2021Aspirant
The problem is that i am sitting on a remote location, due to which i can access RBR remotely, but cant access RBS from outside.
Is there any other solution from which i can do that.
- FURRYe38Mar 03, 2021Guru - Experienced User
