Deepak_Mehta
Mar 03, 2021Aspirant
Firmware Update Issue
My RBR850 is updated but my RBS are not getting updated.
- Mar 03, 2021
If you had a wired PC connected to the system there and had a remote control program like Teamviewer installed on the PC, you could update the RBS remotely. If not, you'll need to be onsite.
Deepak_Mehta
The problem is that i am sitting on a remote location, due to which i can access RBR remotely, but cant access RBS from outside.
Is there any other solution from which i can do that.
Mar 03, 2021Guru - Experienced User
- Deepak_MehtaMar 03, 2021Aspirant
- FURRYe38Mar 03, 2021Guru - Experienced User
:smileywink:
