nmeskin
Oct 07, 2022Aspirant
Firmware update RBR750
Hi, I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware...
michaelkenward
Oct 07, 2022Guru - Experienced User
Something odd going on here.
I see no sign of that ever being firmware for this device.
Orbi RBR750 | WiFi System | NETGEAR Support
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
