nmeskin
Oct 07, 2022Aspirant
Firmware update RBR750
Hi, I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware...
Oct 07, 2022Guru - Experienced User
Are you seeing same thing on the RBS? Be sure to update the RBS first then the RBR lastly. RBS use the RBS.chk file.
