nmeskin
Oct 07, 2022Aspirant
Firmware update RBR750
Hi, I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware...
Oct 07, 2022Guru - Experienced User
Would you confirm that this is the right FW version on your RBS and RBR?
I don't see this in NGs prior FW version history.
Is this Orbi system a retail system you bought someplace online or did you happen to get it from a ISP company by chance?
nmeskin wrote:
Hi,
I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware. I downloaded the firmware from the website for manual upgrade but the file extension is .chk while as per user manual, it should be .img.
Regards
