nmeskin
Oct 07, 2022Aspirant
Firmware update RBR750
Hi, I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware...
Oct 13, 2022Guru - Experienced User
Any progress on this?
nmeskin wrote:
Hi,
I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware. I downloaded the firmware from the website for manual upgrade but the file extension is .chk while as per user manual, it should be .img.
Regards
