Nobber1066
Dec 23, 2024Aspirant
Firmware update RBRE960 Whats the Story?
I have a RBRE960 router and satellites which I have had for about 9 months I moved from BT Whole home WIFI I chose the Orbi because the write ups were all pretty good even though they are very expens...
Dec 23, 2024Guru - Experienced User
I'd roll back the firmware. I had the RBK963 and it was super stable for the longest time. When upgraded to the RBE973, I missed the 963 because it was so much more stable than the 973.
Its evened out a little but I still like my 963.
Try the rollback, full factory reset, and reinstall. Then disable auto-updates.
See if the next version is more stable.
Nobber1066
Ok I'll give it a try but 21 was released months ago and waiting for 31 to be stable and usable in the UK is like waiting for a bus...
Thanks for the reply
- plemansDec 23, 2024Guru - Experienced User
Waiting on firmware updates always is. Most of the security updates aren't that "critical" and tend to be security that most end users don't need
- FURRYe38Dec 23, 2024Guru - Experienced User
Be sure you downgrade the RBS first, then RBR lastly. After all is downgraded, you'll need to factory reset and set up the system from scratch.Or if you have a saved backup from when the system was on v.21, you can load it up and should be up and running with in minutes.
- Nobber1066Dec 23, 2024AspirantSorry do.you mean downgrade to v7 21 not v6
If your in the EU region, I think that v.21 wasn't available for that region. You'll need to downgrade back to the last v6 version.
