miguelangelnet
Nov 02, 2021Guide
Firmware Update v4.6.5.8 - CBR750
I just have a firmware update v4.6.5.8 for the CBR750 from the "Firmware Update" section, but I don't find any documentation from the NETGEAR website. Is safe to update?. thanks!
Nov 02, 2021Guru - Experienced User
A lot of times they choose a smaller subset of routers to push the update to or that can get it from the manual update server.
Its usually been tested pretty well in house.
so is it safe? Tough to say unless you've tried it.
You could make a backup configuration of your current setup.
If it has issues, you can downgrade and restore your backup.
