Popcorn2007
Oct 29, 2022Aspirant
Firmware upgrade issue
Received email advising firmware upgrade. However when I check for updates just comes back with ‘Firmware check error’
- Nov 01, 2022
CrimpOn
Oct 29, 2022Guru - Experienced User
How I envy customers who get email from Netgear. Bought my Orbi in 2016. Registered it. Have never received any sort of email.
This situation reflects the disjointed nature of Netgear support mechanism. It appears that the mechanism sending out email notices (to some customers) and the mechanism that "flips a switch" so that routers find updates when they search are not in sync.
There is a sort of mantra on the forum, "If it ain't broke, don't fix it." Meaning that a customer who is not experiencing any sort of issue with the system should feel no urgency to change the firmware. (Customers who are having problems are a different issue.)
Until the router "finds" the new firmware, the only was to update the firmware is to browse to the Netgear support site:
https://netgear.com/support Enter the product name (such as RBR750). Click on the link that comes up. Click on Downloads.
Then, download the firmware version you want (latest in your case).
Unpack the zip file to extract the firmware image.
Use the Manual Tab on the firmware update page to upload the firmware image.
Or..... wait until the router does it automatically.
Popcorn2007
Thanks for your quick response - just concerned as email indicated it was a security enhancement
- CrimpOnOct 29, 2022Guru - Experienced User
Yes, this does put customers in an awkward bind. "Hurry and do this now", but then the router says it can't find new firmware.
As Pooh would say, "oh. Bother."
Perhaps if you post the product number of the router and the current firmware release (found in the upper right corner of the web browser interface home page) or (somewhere) in the Orbi 'app', someone could comment on how significant this update is.
- Popcorn2007Oct 30, 2022Aspirant
Hi,
Thanks for the reply
- Popcorn2007Oct 31, 2022AspirantJust a thought the email came recommending an upgrade was from [email protected]. Is this a legitimate email for netgear? Looked ok as knew the model number of my Orbi
- FURRYe38Oct 31, 2022Guru - Experienced User
What model Orbi do you have?
