joshadam1984
May 07, 2020Aspirant
Firmware v3.2.10.11 Frequent Disconnects
Hello. Over the past couple months I’ve noticed frequent disconnections from a couple of my RBS850 satellites. I have three satellites in all.. with a stand-alone modem (Only) and the RBR850 as my rou...
May 07, 2020Guru - Experienced User
Have you loaded v11.2 on everything then factory reset and setup from scratch, set CTS/RTS values to max then see if problem reappears?
- joshadam1984May 07, 2020AspirantI haven’t adjusted the channel— it is auto currently so will try changing it.
Wifi neighbors— normally 1 sometimes 2 show up.
One is more then 30 ft, blue does flash blue when syncing.
I did a factory reset after it automatically pushed the firmware back to v3.2.10.11.
CTS/RTS were changed and all Orbi systems rebooted.- FURRYe38May 07, 2020Guru - Experienced User
Try v11.2 if needed.
Has there been good feedback on the 11.2 version? I will definitely look into manually updating it to 11.2 if so.
Also, it really seems to be isolated to one of my RBS850 satellites as opposed to the RBR850, itself. I say this because I was still able to work on my laptop.. which was connected to the router.. however, our living room Roku was consistently disconnecting. This Roku was connected to one of the RBS850 satellites. I tried a wired and wireless connection and it kept occuring. As a result, I swapped the placements of two of the RBS850 satellites with one another and the Roku has held on strong for the last 3 hours whereas before it'd disconnect every 30-45 mins.
If I can isolate it to the one satellite having the issue then certainly could assist in potential troubleshooting.
Thank you!
- FarmerBob1May 07, 2020Luminary
CTS/RTS were changed and all Orbi systems rebooted.Yesterday I was having all kinds of trouble after being in 11.2 for a while and IoT Devices that work fine on their own, but weren't interacting with eachother as they should. I did a Back-Up and a Factory Reset in preparation for reverting to 10.11 from 11.2. As I was getting ready to load 10.11, I realized that when I installed 11.2 I didn't do any of the "adjustments" that I have discovered needs to be changed. So I restored with the Back-Up that I just made, then turned off CoEx. Alexa is not only talking to my kinda old AV gear, but changing settings and inputs.
Just for giggles, try just turning off the 2.4GHz/5GHz Coexistence setting. That has fixed these issues many times for me. The next thing to try is turning off AX Features. After I did the restore I started off with CTS/RTS is at 64, the default. I also have left the channel at "Auto". Which with Netgear, they usually do a pretty good job of dodging congested frequencies. That is "usually". But with the changing of the Coex, I upped the CTS/RTS to the max of 2347. Preamble at "Automatic", was "Short", and Power 100%. The third thing I do is turn off WMM (Wi-Fi multimedia) settings on both 2.4 & 5GHz. This has come from the step by step trouble shooting I have had to do.
Let us know what happens . . .
Stay Smart, Safe & Well . . .
. . . fb
Thank you for the detailed troubleshooting options, fb. I'm trying to see if it may just be limited to one of the satellites having an issue as opposed to the RBR850, itself. I'll keep you all updated after I replace them a few times and see how long they stay connected.
Are there any easy ways of monitoring satellite disconnections?
