joshadam1984
May 07, 2020Aspirant
Firmware v3.2.10.11 Frequent Disconnects
Hello. Over the past couple months I’ve noticed frequent disconnections from a couple of my RBS850 satellites. I have three satellites in all.. with a stand-alone modem (Only) and the RBR850 as my rou...
May 07, 2020Guru - Experienced User
Have you loaded v11.2 on everything then factory reset and setup from scratch, set CTS/RTS values to max then see if problem reappears?
joshadam1984
I haven’t adjusted the channel— it is auto currently so will try changing it.
Wifi neighbors— normally 1 sometimes 2 show up.
One is more then 30 ft, blue does flash blue when syncing.
I did a factory reset after it automatically pushed the firmware back to v3.2.10.11.
CTS/RTS were changed and all Orbi systems rebooted.
