joshadam1984
May 07, 2020Aspirant
Firmware v3.2.10.11 Frequent Disconnects
Hello. Over the past couple months I’ve noticed frequent disconnections from a couple of my RBS850 satellites. I have three satellites in all.. with a stand-alone modem (Only) and the RBR850 as my rou...
joshadam1984
I haven’t adjusted the channel— it is auto currently so will try changing it.
Wifi neighbors— normally 1 sometimes 2 show up.
One is more then 30 ft, blue does flash blue when syncing.
I did a factory reset after it automatically pushed the firmware back to v3.2.10.11.
CTS/RTS were changed and all Orbi systems rebooted.
May 07, 2020Guru - Experienced User
Try v11.2 if needed.
- joshadam1984May 07, 2020Aspirant
Has there been good feedback on the 11.2 version? I will definitely look into manually updating it to 11.2 if so.
Also, it really seems to be isolated to one of my RBS850 satellites as opposed to the RBR850, itself. I say this because I was still able to work on my laptop.. which was connected to the router.. however, our living room Roku was consistently disconnecting. This Roku was connected to one of the RBS850 satellites. I tried a wired and wireless connection and it kept occuring. As a result, I swapped the placements of two of the RBS850 satellites with one another and the Roku has held on strong for the last 3 hours whereas before it'd disconnect every 30-45 mins.
If I can isolate it to the one satellite having the issue then certainly could assist in potential troubleshooting.
Thank you!
- FURRYe38May 08, 2020Guru - Experienced User
I haven't seen any disconnects with my system on v11.2.
The only problem is that the backhaul status reporting in the RBR in broke while the RBR is in AP mode if you connect RBS to the RBR with a Gb lan switch in the middle. :smileyfrustrated:
