joshadam1984
May 07, 2020Aspirant
Firmware v3.2.10.11 Frequent Disconnects
Hello. Over the past couple months I’ve noticed frequent disconnections from a couple of my RBS850 satellites. I have three satellites in all.. with a stand-alone modem (Only) and the RBR850 as my rou...
Sevo123
May 09, 2020Apprentice
Im on version 3.2.11.2 and my devices are disconnecting constantly its so annoying! I regret buying my rbk853 and giving netgear $1000 smh !!!! Do upset that they cant fix this stupid disconnecting issue. Before on my rbk53 unit they did the same thing in the beginning then finally fixed this situation now a new product and new problems... Their phone support is garbage now. They cant even help
May 10, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
