antonjosh
Jun 02, 2020Aspirant
Firmware V3.2.15.25_1.3.15 - Media Player Buffering
Can anyone help me why all of a sudden our Roku and Firesticks have started buffering after the upgrade to the new firmware for our AX6000? I followed what everyone have suggested to change CT to 234...
Jun 02, 2020Guru - Experienced User
Downgrade back to v11.2.
- antonjoshJun 02, 2020Aspirant
Yes I did it for all 3. Is there an order of resetting it?
- FURRYe38Jun 03, 2020Guru - Experienced User
Not really, I would reset the RBR first then RBS lastly as if you do the RBS first and you don't reset the RBR quick enough the RBS could auto re-connect by themselves.
I acutally reverted back to v11.2 not for buffering however for NEST controller problem. See if this works for you.
