Iantull
Nov 13, 2023Guide
Firmware version for RBR850 update advise
I have an RBR850 and 4 RBS850 satellites installed and having some issues with the satellites dropping connection. On looking at the FW Version I see I am running V4.6.14.3_2.3.12 and when I check f...
- Nov 15, 2023
I had been using my MacOS Laptop (Safari only) for all my tries to connect to the Satellites (without success) and even using the password the same as the router.
After searching through other posts I found others using Chrome etc, so decided to use my installed Chrome on the same laptop, it worked, I was able to login fine to each Satellite and have successfully updated all Satellite FW. I still need to do the router but that will need to be tonight.
I'm hoping all will go well, but I thank those that made suggestions.
So my problem looks as though it just won't work with Safari but works fine using Chrome.
Ian
Nov 14, 2023Guru - Experienced User
I like to log in manually to each satellite/router if I'm concerned with a drop bricking my device.
You could be able to look up the satellites IP address and log into them and do it.
Just make sure to do the satellites first and the router last.
