Iantull
Nov 13, 2023Guide
Firmware version for RBR850 update advise
I have an RBR850 and 4 RBS850 satellites installed and having some issues with the satellites dropping connection. On looking at the FW Version I see I am running V4.6.14.3_2.3.12 and when I check f...
- Nov 15, 2023
I had been using my MacOS Laptop (Safari only) for all my tries to connect to the Satellites (without success) and even using the password the same as the router.
After searching through other posts I found others using Chrome etc, so decided to use my installed Chrome on the same laptop, it worked, I was able to login fine to each Satellite and have successfully updated all Satellite FW. I still need to do the router but that will need to be tonight.
I'm hoping all will go well, but I thank those that made suggestions.
So my problem looks as though it just won't work with Safari but works fine using Chrome.
Ian
Iantull
Nov 15, 2023Guide
Thanks for that information, I did read in the manual that you should do the satellites first and yes I can get to each ones IP address. The problem I am having as far as satellites is concerned is that it won't allow me to login to them. I enter admin and "password" (as I didn't change that) but it fails, I even tried other passwords, the same as what I changed the router to, but again it doesn't work. I'll need to put up another subject request to see why I'm having this issue.
Ian
CrimpOn
Nov 15, 2023Guru - Experienced User
Satellites use the same credentials as the router: "admin" plus a password.
