fli
Aug 06, 2021Follower
firmware vunnerability
It's unbelievable that the firmware is so vulnerable: 1. admin web login with clear text password without TLS or SSL 2. The CVE-2018-10822 issue 3. No way to stop SSID broadcasting With this p...
Aug 06, 2021Guru - Experienced User
1. admin web login with clear text password without TLS or SSL < Most routers don't need any TLS or SSL on the admin log in from a local side. Been like this for a long time now.
2. The CVE-2018-10822 issue< This issue is in regards to D-Link effected routers. Not NG.
3. No way to stop SSID broadcasting< Been like this since Orbi AX released.
With this price tag, could you enhence the above?
