Edwardlotz
Aug 16, 2020Guide
Firmware will not update on router and satellite says service unreachable
I hAve Orbi ax6000 rbr850 router and one satellite. In firmware admin it show a new firmware version v3.2.16.6 but it will not upgrade to it and the satellite says service unreachable. The past server...
Chuck_M
Aug 16, 2020Mentor
Try and disconnect any wired devices (other than PC) and attempt again. You dont have any other RBR50s attached do you?
Edwardlotz
Aug 16, 2020Guide
I bought the package that had the router and one satellite. I will try your suggestions as soon as I can.
I don’t think I mentioned I didn’t have this issue when I bought 4 months ago. It only started after one of the first firmware updates. Thanks
