Edwardlotz
Aug 16, 2020Guide
Firmware will not update on router and satellite says service unreachable
I hAve Orbi ax6000 rbr850 router and one satellite. In firmware admin it show a new firmware version v3.2.16.6 but it will not upgrade to it and the satellite says service unreachable. The past server...
Edwardlotz
Aug 16, 2020Guide
Netgear cm1000
Aug 16, 2020Guru - Experienced User
Have you factory reset the RBR and RBS, have the RBS in the same room as the RBR then walk thru the setup wizard to see if it picks up the new FW update for both RBS and RBR? I would use Edge, IE11 or Firefox browser to try this.
- EdwardlotzAug 16, 2020GuideI am planning doing a reset of just the router but I guess you recommend doing both.
- FURRYe38Aug 16, 2020Guru - Experienced User
Yes.
