Faarr
Jun 13, 2024Initiate
First time instalation
Just bought the rbk853 at first time installation, i had a firmware update. I connected my Orbi router with my modem. After that the router worked but i cant connect the 2 satellites. I resetted the r...
Faarr
They are hardwired, thought my wall outlet. How do i know if they have the same firmware?
Jun 14, 2024Guru - Experienced User
Take the satellites too where the router is, factory reset the satellites, and use a known good 6ft cable and hardwire them into the router. Then give it a bit for everything to boot up and log in through the GUI (browser) and see if they connected. From the GUI you can check the firmware.
