atoato
Jun 11, 2022Aspirant
fixed 4.6.8.2 on RBR 850
So i went blindly into the FW update lime most others and ended up with no access to http. After about 6 hours or trial and error and stepping through the whole process i figured out wha tthe proib...
CrimpOn
Jun 11, 2022Guru - Experienced User
OpenVPN is not a web service. (at least on the older model Orbi) OpenVPN host is configured to listen for connections on ports 12973 and 12974.
atoato
well i had moved mine to 443. it always worked and openvpn actually listens and redirects https traffic as a proxy to the httpd, and processes vpn traffic itself.
It does not work properly on 4.6.8.2 and is the reason 4.6.8.2 breaks admin access for others.
- FURRYe38Jun 12, 2022Guru - Experienced User
Though I don't use Orbi VPN, Iv'e not have or seen any problems accessing the RBRs web page on v.2 FW. For those that did see this issue, a full on factory reset and setup from scratch help those re-gain access to the RBRs web page after theres were auto updated.
I don't believe the port your using would be a valid port for any VPN use. Something to ask NG support about and see.
