Haselmaier's avatar
Mar 31, 2022
Fixed IP Addresses On Guest Network
I use the Guest Network for IoT devices.
Is there a way to have consistent/fixed IP addresses on the Guest Network?  It appears the Address Reservation capability in the router is only for the private network.
Thanks.
Jim
  • CrimpOn's avatar
    CrimpOn
    IP assignments are based on device MAC address. Applies to any network.
    • Haselmaier's avatar
      Haselmaier
      Guide
      When I attempt to do an Address Reservation:
      *  They're only allowed on IP addresses in the DHCP Server range.
      *  DHCP Server range only allowed in the 192.168.1.* network.
      *  Guest Network is in 192.168.2.* range.
      *  I don't see a way to change the subnet for the Guest Network.
      When I attempt an Address Reservation the page makes it look like I can change the subnet for the reservation being made, but an error is generated when the reservation is Applied.  (Error is something like "Address reservations can only be made in the DHCP range.")
      Firmware version:  V4.6.5.14_2.0.54
      • CrimpOn's avatar
        CrimpOn
        You are, of course, entirely correct.  Netgear "changes things" from one Orbi product to the next.  Guest network IP addresses is one of the things that changed (I knew that, but when the time came to remember it, "poof".)  On the original Orbi, Guest WiFi IP's were in the same subnet as primary WiFi IP's.  That changed with the AX series.
        My guess is that "Guest" means "a device that comes for a while, and then goes away, perhaps never to be seen again."
        Sorry I messed up.
