CarlJohnDensley
Sep 06, 2022Aspirant
flashing white light on orbi RBR750 despite everything
Tried it all. Rebooting with paper clip. Yes it flashed yellow then back to white. Tried using the app to reinstall. Nothing. It doesn't find the satellite. Tried support. They promised a call back. ...
CarlJohnDensley
Sep 07, 2022Aspirant
Thank you. Following your comment I turned off the main router from my service service provider but didn't help. It just keeps flashing then pulsing white.
ekhalil
Sep 07, 2022Master
CarlJohnDensley wrote:Thank you. Following your comment I turned off the main router from my service service provider but didn't help. It just keeps flashing then pulsing white.
You can't just turn off the main router. You need to set it to bridge mode or change Orbi to AP mode.
