Jeremycoppey
Nov 02, 2021Aspirant
Force Daisy Chain on a AX4200 RBS750 satellite
Hi experts, I have a setup with 1 AX4200 RBR 750 router and 2 RBS 750 satellites. Firmware version: V4.6.5.14_2.0.54 1 satellite is connected with a wired backhaul to the router, the second one...
Nov 02, 2021Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Then power OFF the wireless RBS for 1 minute then back ON, it should connect to the other RBS...
Orbi AX systems never had Daisy Chain options in the FW UI.
