Jeremycoppey
Nov 02, 2021Aspirant
Force Daisy Chain on a AX4200 RBS750 satellite
Hi experts, I have a setup with 1 AX4200 RBR 750 router and 2 RBS 750 satellites. Firmware version: V4.6.5.14_2.0.54 1 satellite is connected with a wired backhaul to the router, the second one...
Nov 02, 2021Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Then power OFF the wireless RBS for 1 minute then back ON, it should connect to the other RBS...
Orbi AX systems never had Daisy Chain options in the FW UI.
Jeremycoppey
Nov 03, 2021Aspirant
Thanks Furry,
I already did al those steps based on posts I found in this community, non of them helped.
Is there no other magic trick? Or do we just wait for another FW release where they will fix those bugs (It worked perfectly in the past)
Kind regards
Jérémy
- FURRYe38Nov 03, 2021Guru - Experienced User
- JeremycoppeyNov 03, 2021Aspirant
Router to Wired satellite (office :in the same house 3 walls in between): 9 meters
Router to Wireless satellite (shed: 4 walls and 1 very good insulated exterior wall) : 24 meters
Wired Satellite to Wireless satellite: 14 meters
If you turn OFF the RBR for 1 minute then back On, does the farthest RBS connect to the other RBS?
