Jeremycoppey
Nov 02, 2021Aspirant
Force Daisy Chain on a AX4200 RBS750 satellite
Hi experts, I have a setup with 1 AX4200 RBR 750 router and 2 RBS 750 satellites. Firmware version: V4.6.5.14_2.0.54 1 satellite is connected with a wired backhaul to the router, the second one...
Jeremycoppey
Nov 03, 2021Aspirant
Thanks Furry,
I already did al those steps based on posts I found in this community, non of them helped.
Is there no other magic trick? Or do we just wait for another FW release where they will fix those bugs (It worked perfectly in the past)
Kind regards
Jérémy
Nov 03, 2021Guru - Experienced User
What is the distance between the router and 📡 satellite(s)?
- JeremycoppeyNov 03, 2021Aspirant
Router to Wired satellite (office :in the same house 3 walls in between): 9 meters
Router to Wireless satellite (shed: 4 walls and 1 very good insulated exterior wall) : 24 meters
Wired Satellite to Wireless satellite: 14 meters
- FURRYe38Nov 03, 2021Guru - Experienced User
If you turn OFF the RBR for 1 minute then back On, does the farthest RBS connect to the other RBS?
- JeremycoppeyNov 04, 2021Aspirant
Dear Furry,
I did that nothing happend.
He still connected to the router
Any other solutions?
Kind regards
Jérémy
