jogotronic's avatar
jogotronic
Force Daisy Chain Setup (RBS850)
Hi,   I have my Router on the top floor and 2 Satellites on the lower floor. The router is on one end of the house and Satellite 1 is in the middle, while Satelite 2 is on the other side of the hou...
  • plemans's avatar
    Jan 17, 2022
    No.
    they have their own internal programming that decides if daisy chaining is faster versus standard connection.
    Just because it shows up as poor, doesn't mean it'd be faster if daisy chained. especially since thats the dual band configuration and not triband. When you daisy chain dual band setups, the speeds get cut in half for every satellite in the daisy chain.
