jogotronic
Jan 17, 2022Aspirant
Force Daisy Chain Setup (RBS850)
Hi, I have my Router on the top floor and 2 Satellites on the lower floor. The router is on one end of the house and Satellite 1 is in the middle, while Satelite 2 is on the other side of the hou...
- Jan 17, 2022
No.
they have their own internal programming that decides if daisy chaining is faster versus standard connection.
Just because it shows up as poor, doesn't mean it'd be faster if daisy chained. especially since thats the dual band configuration and not triband. When you daisy chain dual band setups, the speeds get cut in half for every satellite in the daisy chain.
jogotronic
Thanks for the fast reply! Is there any way of getting more detailed info on the connection quality between a Satellite and the Router? What does bad mean and how is it affecting the connection?
Jan 17, 2022Guru - Experienced User
Not sure on the 350 series about the connection quality.
What you can do is test it.
Hardwire into each satellite and test its speed.
Like I said because of that speed drop dual band systems take, you might still have faster speeds with the direct connection than you would going daisy chained.
