PhilDaNoob
Feb 05, 2024Aspirant
Force Plystation Portal onto 5ghz band.
Hi everyone, I have a Netgear Orbi RBR850. At the weekend I purchased a Sony PlayStation Portal. The Portal is suppose to run on a 5Ghz band. How do I force the Portal onto the Orbi’s 5ghz band? Man...
michaelkenward
Feb 05, 2024Guru - Experienced User
You'll have to ask the people who made the portal.
By design the Orbi broadcasts both 2.4 and 5 GHz. it is up to your devices to connect.
If the device doesn't work with 2.4 GHz, it won't see it.
