PhilDaNoob
Feb 05, 2024Aspirant
Force Plystation Portal onto 5ghz band.
Hi everyone, I have a Netgear Orbi RBR850. At the weekend I purchased a Sony PlayStation Portal. The Portal is suppose to run on a 5Ghz band. How do I force the Portal onto the Orbi’s 5ghz band? Man...
Feb 05, 2024Guru - Experienced User
What FW is loaded on the RBR?
Any RBS deployed? If so, how many?
What channel configurations are currently set on the router?
On new FW, there is options to get devices ON 5Ghz on Orbi 8 series systems.
However it is up to client device to connect to either frequency based on design and support. Be sure your device supports 5Ghz. Most 5Ghz supporting devices usually pick 5Ghz first thing when connected if 5Ghz signal is present. Could fall back to 2.4Ghz if something is not working right or not configured right.
PhilDaNoob wrote:
Hi everyone,
Many thanks!
