PhilDaNoob
Feb 05, 2024Aspirant
Force Plystation Portal onto 5ghz band.
Hi everyone, I have a Netgear Orbi RBR850. At the weekend I purchased a Sony PlayStation Portal. The Portal is suppose to run on a 5Ghz band. How do I force the Portal onto the Orbi’s 5ghz band? Man...
CrimpOn
Feb 05, 2024Guru - Experienced User
PhilDaNoob wrote:
Hi everyone,
Many thanks!
As others have commented, the Orbi system does not provide a mechanism to force a product to connect at 5G.
In the discussion, I did not see information regarding what connection it has. Is it connecting at 2.4G or 5G?
- FURRYe38Feb 05, 2024Guru - Experienced User
One can setup the IoT network for 5Ghz only broadcast on v7 FW I believe.
